メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
締切られた回答
Phone doesn't react – How can I find out what's wrong?
Hey everyone,
I was using an iPhone 3GS which I bought in January 2010. My power button hadn't been working for a while now but I could get around with Apple's native Assistive Touch. I realized over the last days that my battery had become very short-lived compare to before, and one day after I had just fully charged it, taking it out of my pockets it didn't react at all anymore. Plugging it in again there wasn't any reaction either.
How can I find out what happened to the phone? My wild guess is that the battery just stopped working, but any other suggestions are welcome. What should I do as a first step?
Many thanks for your help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Duci, before anything else, replace the battery. This will give you a clean known to be good starting point in case you need further troubleshooting. Hope this helps, good luck
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you, Old Turkey and Mitch Rush, for your answers. I have a 3G battery readily available, is it adviseable to build it in my 3GS just for checking whether the battery is actually the problem? That would speed up the process enormously…
さんによる
コメントを追加
Duci, I agree with Old Turkey,, if you are still having problems after a new battery than I would replace the dock connector.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 361
