メインコンテンツにスキップ
The Motorola Droid RAZR Maxx is a version of the Droid Razr carrying a higher capacity 3,300mAH battery.
20回答 すべてを表示
HELP!my phone completely broken won't power off &alarmclock wont stop
My phone got smashed so I have a cracked screen and all the buttons are messed up. I try the power button it won't shut off i try power button and + or - volume key and that won't work...so my phone is stuck on and to make it worse my alarm clock keeps going off and I can't make it stop going off cause the buttons don't work and my screen is completely black.if it wasn't for the alarmclock and led lights blinking you wouldn't even realize its on..I'm about to go crazy please help I just need to power this dang thing off
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
Lindsay, start off by removing the battery. Use the first minute of this video to get it accomplished. After that you may have to disassemble your phone totally to evaluate the damage, Repair/replace the parts as necessary starting with the display assembly. Hope this helps, good luck
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
You can try rebooting your system just hold the power button for 120 seconds and it should cut back on and you should still have your stuff back
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Not difficult people, remove the battery!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lindsay さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 20
今までの合計 2,437
