メインコンテンツにスキップ
Appleが発売した全てが一つに詰められたデスクトップコンピューターです。iMacは2006年1月以来、Intelプロセッサーを導入してきました。
7465回答 すべてを表示
iMac 27" buzzing and will not power on now?
my iMac 27" was making a buzzing noise in top left corner (if looking at it from front) when on and I tried both resets nothing worked. It was asleep and after a storm will not power on at all now. I tried unplugging for a few minutes and plugging back in, waited over 24hrs and still nothing. Any ideas? Power supply?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
ok so i unplugged the power cord from back and waited 24hrs. Plugged it back in and it powered up but still has loud buzzing coming from the top left corner. Power supply causing the buzzing?
さんによる
What are the last four figures of your serial number ( located on the bottom of your stand)? This tells us which machine you have.
さんによる
Last four are DHJV Thanks
さんによる
コメントを追加
1 件の回答
ベストアンサー
The power supply is indeed located in the top left corner and over the years power supplies have often exhibited buzzing sounds when they are failing. The LED driver board is also in that area though it doesn't have nearly as much power flowing through it so buzzing would be kind of odd. With what you've given us I'd say the power supply is probably a safe bet.
With that said, if it fails again I would check the diagnostic LEDs to see where the power flow is failing. Most of the 27" iMacs (before they lost the optical drive) have 4 diagnostic LEDs just to the left of the RAM slots, visible through the grill at the bottom of the Mac.
LED 1 indicates trickle power is present, this should always be lit if the Mac is connected to a power source.
LED 2 indicates that the logic board has received power from the power supply. This is the one I'd expect to see be either noticeably dimmer or dark compared to the first one if the power supply is flaky.
LED 3 indicates the video card is functioning.
LED 4 indicates that the display is functioning.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Ok I will check those out and let you know. Thanks
さんによる
コメントを追加
回答を追加する
Brandon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 21
今までの合計 2,748
