Dropped & screen is cracked
I dropped my Ipad Mini. Not very smart when it comes to these devices. What do I need to buy to fix the screen?
この質問は役に立ちましたか?
Tom,
For the iPad mini the replacement glass screen, aka digitizer, comes in two flavors.
1.) A plug and play option---which is described as "iPad mini digitizer with touchscreen ic and presoldered home flex"
2.) A 'glass only option' --which requires you to desolder and transfer the original touchscreen ic and home flex from your cracked digtizer.
I'll also add that a couple of idiots on eBay actually sell glass only which is a useless piece of glass that is not even a digitizer for the same price as a digitizer.
iPad mini screen replacement is hated by many repair shops--those suckers can give you a lot of problems. Make sure to read up on this repair before you begin to try--there can be a lot of pitfalls---especially cracking the LCD on disassembly, blowing the backlight fuse, removing pins from the digitizer connector on the motherboard, and digitizer ghosting.
Nevertheless, this repair is do-able as a DIY project---on this one it will definitely pay off to do a little more research than usual.
このアンサーは役に立ちましたか?
Hi there is it just cracked does the picture at all look damaged if not then you just need to buy the glass digitizer
このアンサーは役に立ちましたか?
The picture looks ok. I think the screen is just cracked. So all I need to purchase is the glass digitizer? Is that a glass type front that slips on?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 265
