オリジナルのiPhone、iPhone 3G、iPhone 3GS、iPhone 4、iPhone 4s、iPhone 5、iPhone 5c, iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s and iPhone 6s Plusのための完全版分解と部品交換ガイド
31364の回答 すべて表示
Why will iPhone not allow me to connect to wifi?
My iPhone worked perfectly for months. Recently, however, I plugged my iPhone into itunes for the first time, to download the 3.1 software and tunes to the iPod. Now, my iPhone won't connect to my wireless internet at my home or office. In fact, when I go to "settings," it says "no wifi." How do I get my phone to recognize my wireless router, as it did before?
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
当社のショップを閲覧する
3回答
選択されたソリューション
Is your iPhone on a contract of jailbroken? If you upgraded to 3.1 there are issues where the wifi just dies. It is a hardware problem and just look at one of the many discussions here:
http://discussions.apple.com/thread.jspa...
You can try some of the tricks there but I am afraid it can be hard to heal it.
It says "no wifi" meaning the iPhone does not recognize the wifi board anymore. I had this issue on 8GB 1.gen. iPhone and bought a new communication board. I got one cheap(er) on ebay. The battery is soldered to it like here: (http://cgi.ebay.com/Apple-iPhone-2G-Comm...) No sweat to replace it. The hard part is always to open the iPhone.
Good luck and I would spend that money on your iPhone since it seems it is working.
この回答は役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Hi,
check that wifi is enabeled in options and the flight modus is off. Can you see your router or just couldn't connect?
この回答は役に立ちましたか?
スコア 1
コメント:
Yes, airplane mode is off. My "wifi" option merely says "no wifi." Can I see my router? Well, it's in my basement and I'm upstairs, but this never presented a problem before. I know my router works upstairs, because that's how I'm using my internet now.
による
I've been having trouble with my iphone 3gs not recognizing my wifi also. I went to settings. turned the airplane mode 'on' and then 'off,' and surprisingly I then had access to my personal wifi. Hope that works for you. Good luck !
による
コメントを追加
The issue might be either hardware- or software- related.
If it is a hardware problem, your iPhone Wi-Fi switch under Settings > Wi-Fi will be turned off and/or greyed out (unable to be turned back on). This happens especially on iPhone 4 and iPhone 4S running iOS 6 and iOS 7 as the Wi-Fi radio chip overheats. Not much to do here except to take it to the Apple Store for replacement.
If it is a software issue, it can get resolved by cold restarting the iPhone and/or by resetting your iPhone network settings via Settings > General > Reset > Reset Network Settings.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
miggy さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 7
今までの合計 11,280
