broken home button clip connector in iPhone frame
i broke the connector on the iPhone metal frame that clips to the home button cable inside the iPhone metal housing, can i fix it or get a replace frame for the iPhone 4?
You can get replacement frames on eBay there not very expensive post a pic of the bit that's broke as I'm unsure what your talking about
このアンサーは役に立ちましたか?
The home button flex connector is a component of the "charging port assembly with flex cable", which also contains the lower mic. This is the replacement part you need.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 198
