メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
HP's 7" tablet released in April 2013 with a few upgrades over the first iterations. Repair for this device is similar to that of other Android tablets, requiring only screwdrivers and a prying tool. Available as 8 or 16 GB / Red or Silver.
24の回答 すべてを表示
Why does my screen have lines distorting the picture?
When I turn my tablet on, there are grey lines across the entire screen both vertically and horizontally. I tried restarting my tablet, but it did not work. Do I need to replace my screen, or can I do something to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
The LCD screen connector may not be fully connected. It's possible for this to happen during normal use, but it usually happens right after doing a repair on the tablet. The only way to fix this is to take the tablet apart and push the LCD screen connector all the way into the port.
Follow the Battery Replacement guide until you get the tablet's back cover off - there's no need to remove the battery. Then remove and re-insert the LCD screen connector, making sure to push it in all the way. Then replace the back cover of the tablet.
この回答は役に立ちましたか?
スコア 1
コメント:
If you had dropped it so hard once or many times, the grey lined will appear , all i know is that LCD screen connector may not be fully connected, as Ryan o Neill said. I will not write it just follow him.
さんによる
コメントを追加
None of the above
They are purse lines
この回答は役に立ちましたか?
スコア 0
コメント:
The lines are purse the show and I can not get rid of them
さんによる
Sharon Campbell is this an answer to the original question or is this something different? Is this what your tablet shows? Give us more information.
さんによる
コメントを追加
回答を追加する
Zachary さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,122
