メインコンテンツにスキップ
2012年11月2日に発売されたiPadの第四世代です。Wi-Fi, CDMAもしくはGSM モデルがあり、16、32、64GBの容量オプションがあります。
408回答 すべてを表示
締切られた回答
iPad won't charge from 10w charger but will from computer.
Hi i Have an iPad 4 wi-fi + Cellular.
This is a really weird issue the iPad when plugged into the Apple 10w charger & lightning cable that came with the iPad comes up with not charging.
I have tried several different chargers lightning cables all with same result i have also replaced the lightning port & even changed the battery.
It will power on the iPad when it is switched off so it knows a charging lead has been connected.
It is recognised when i plug it into iTunes I can sync ETC & i have reset & activated the iPad through iTunes via DFU too.
Strangely when connected to my Mac it shows the charging icon where normally an iPad would show not charging when connected to a computer.
Apparently it will also charge ok from a 5w iPhone wall charger.
I did purchase the iPad in this condition with the intention of refurbing & repairing the issue.
Its like the charging has flipped in reverse
Its got me stumped any ideas or help greatly appreciated.
Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Is it actually not charging, or just saying that it is not charging?
I had an iPad mini like this once---I tried a few different dock connectors and what I remember is that it would say 'not charging' but it would actually charge up just fine.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Hi Jessa
Thanks for replying.
No its not charging the % does not go up but it doesn't go down either when you use it.
What is weird is when connected to a computer they normally say not charging but this has been reversed it shows the little lightning icon next to the battery icon indicating its charging i shall leave it a while to see if it does actually charge it.
What is mad is i have just plugged it into an iPhone 5W charger & it has now come up with the lightning icon next to the battery & says its charging ????
さんによる
Does the low battery logic engage when charge falls below 5%?
さんによる
Not Sure battery is still up over 20% at the moment.
Will let you know when it gets down to 5%
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 500
