メインコンテンツにスキップ
Wi-Fi, GSMとCDMA モデルのiPad第二世代です。あるモデルはiPad3発売前に改良されたものがあります。修理は困難で、熱で温めてこじ開ける作業が必須です。
728回答 すべてを表示
Display screen colors distorted
My little sister dropped my iPad 2 on the floor. The colors on the screen are a bit out of their normal color. The screen looks a bit also like an old version of a t.v. with scratching lines. The keyboard is green. Once you unlock the iPad the screen looks like the colors of a 3-D screen. Help please! http://m.youtube.com/watch?v=UXfSdG-CwYU
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 190
111 件のコメント
It worked! Who would think 10 whacks on the back would fix it but it did! Thank you..........
さんによる
The screen is green. Tapping did not work.
さんによる
OMG it worked. Thanks
さんによる
I left my iPad in the car and it overheated then chasing my screen to be distorted in color. I let it cool off for a while in hopes that's what it was. Whacking it really helped. THANK YOU SO MUCH!!
さんによる
my fathers ipad is doing the same thing like the version of and old tv. Help!
さんによる
106件以上のコメントを表示
コメントを追加
13件の回答
ベストアンサー
Before you go replacing the LCD try giving the back of the iPad a solid smack with your hand. There are many cases where the iPad has been dropped knocking the LCD cable slightly loose. Hitting it may knock it back in place. Do a search on this site and you'll see many examples of this.
このアンサーは役に立ちましたか?
スコア 90
103 件のコメント:
Found out from other forums that way to fix it is to turn it over and give it ~10 slaps on the back! Believe me it works ( got it off other forums )
さんによる
Can confirm the smack on the rear case does work
さんによる
Lol that worked I can't believe it!
さんによる
I was extremely skeptical of this, specially because mine seemed to be much more skewed than what others seemed to be reporting. I tried it and it improved drastically but still wasn't back to normal so a few more pops and presto, it was like magic! Who ever said violence solves nothing!
さんによる
Well this definitely works. Dropped mine just now and was in despair - until I decided to give it some good smacks....and fixed.
さんによる
98件以上のコメントを表示
コメントを追加
A hard smack on the back--left side will set it right---for now. Ultimately you'll need to open that sucker up and properly re-seat the LCD cable.
このアンサーは役に立ちましたか?
スコア 31
35 件のコメント:
thank you it worked
さんによる
this is not working for me. Do I need to get the cable properly reseated?
さんによる
Make sure it's on the left side, middle to top. Worked great for me.
さんによる
Omg it actually worked!!! Don't think this is a hoax--dropped iPad last night and colors were totally off. Three good whacks to the back left and totally back to normal! Wow!
さんによる
OMG indeed! I dropped it in its case and the colors were totally off, scrambled, it wasn't usable. Ten whacks to the upper middle left and presto! Woohoo! Saved me an expensive repair bill. GREAT advice!!!
さんによる
30件以上のコメントを表示
コメントを追加
So I just knocked my iPad off the side and my screen went very fuzzy and the colours changed,I read this and I smacked it a few times on the back and nothing seemed to have happened,I then smacked all parts of the back of the iPad,I turned it back round and it had looked like nothing had happened however when I was scrolling down to read a few more of the suggestions,I had started panicking at this point however I was scrolling down for more for approxametly 20 seconds,I looked back at my screen to try another suggestion and then it was SUDDENLY back to normal if not better I 100% recommend trying this as it worked an absolute dream for me x
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Did not work for me
さんによる
It did just wait for a while …
I was reading this and I left safari and boom
さんによる
コメントを追加
Can I get it changed at the istore? It's less than one year old.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yooooooooo this is crazy but me and my roomate were making crazy videos and my ipad fell...started getting distorted. I thought it was done for. I joked that if i just slapped it like it fell maybe it would magically work. Googled ipad display problems and found this site. Blown away at all the actuall responses to just smack it....butttteerraa ya girl did it and my baby is back in business!!! Took about a min bit it worked!!!!!!!!!! Hallellujah
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
You are a life saver. Smacked 20-30 times and left it for over 2 mins aaanddd Its alive
さんによる
コメントを追加
Someone please I need somebody’s help NOW! My iPad Air 2 just dropped today and I can’t get it fixed, while I was watching YouTube videos, I thought that the colors looked weird, and that was I thought. My entire iPad has been punished with blue, pink, fuzzy green, and red colors. I was looking up here, and the only way is to smack and whack it. I tried it and it can’t do the trick. I did it almost 100 times roughly whacking it, but it just made it worse. Please help me here, I can’t deal with flashing colors.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Mine too!! God! It actually didn't work ☹️☹️☹️☹️ What we do now???
さんによる
take it in for repair so the LCD cable can be put back in place.
さんによる
コメントを追加
tried tapping the back of my iphone but it didn’t work at all.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
this is for IPads... the phones are more sturdy and have different set up... take it for repair... to have the display cable securely connected.
さんによる
コメントを追加
wow, i was starting to panic
i did both a few solid slaps and a few punches (but hitting with the soft squishy part of my fist not my knuckles) but that didnt get me anywhere, so after reading through all these comments i though, every one is saying to hit it solidly on the left hand side, so i took a hit near the bottom and the on the top of the ipad (on the back obviously) with the squishy part of my fist and boom, all the colours clicked back into place
looks live ive got to start taking better care of this thing XD
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Believe it or not,it’s really worked after 10 times of hard smack!Dropped my ipad 2 yesterday and came across this solution!Thanks,God it’s fixed and back to normal now :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Is this a joke??? I tried this - nothing happened except that my hand hurt
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No, try dropping it. Preferably on carpet and not from too high. I thought it was weird too but it worked for me.
さんによる
コメントを追加
It worked!! Thank you! I really thought it wouldn’t but it did. Thank you so much!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My Grandfathers iPad has weird colors on it it is kinda of like it is inverted but I can still see the original colors I tried hitting really hard on the back multiple times but it is not working and I hit it every where
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Just woke up to my 2020 iPad Pro 12.9 doing the same old TV flickering. Give the back 3 smacks with my palm, good as new again! Thanks!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Glyzza さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 59
過去 30 日: 285
今までの合計 368,885
