メインコンテンツにスキップ
G4 wont start power ring is green but battery dosent charge
My iBook g4 will not start when on the ac adaptor , but will on battery alone . here is the problem when i plug in the adaptor by itself thering is green but iBook will not start when i put battery in the ring turns yellow /orange and still will not start do I need a new dc board?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
Does the battery charge?
さんによる
コメントを追加
2件の回答
最も参考になった回答
Sounds to me like your charger is faulty.
Or it could be your DC in board. You can find out how many cycles are on a battery by using System Profiler and choosing POWER you can also see if it's charging.
The charger could not be putting out enough current to run the computer, certainly not enough to run the computer and charge the battery, but enough to charge the battery when the machine is off... a short in the DC board could present the same.
Good Luck,
N
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
+ Ralph
さんによる
コメントを追加
go to apple store put a new battery in if they have one u can barrow plug into there charger if doesn't work than its your dc in I just replaced mine now it works great.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jefferson Morgan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,296
