Audio Cable is Broken!
My audio cable is not working. What should I do in order to fix the cable?
It depends on what problem you are having with the audio cable.
You can check the following troubleshooting guide (Troubleshooting Beats Studio First Generation) to help diagnose the problem.
If all else fails, the guide recommended by oldturkey03 should be great for soldering on new jacks. If the in-line buttons are the problem, it would probably be easier to buy a new cable.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 671
Where is is broken? At the ends by the connector?
oldturkey03 さんによる
