touch not working only touch
touch not working only touch . screen work but touch not work
この質問は役に立ちましたか?
この質問は役に立ちましたか?
mutaman, you do not need to get a new phone. You will need to get a new digitizer. since the display assembly is fused, and you most certainly do not have a LCD separator tool at hand, I suggest to you replace the front panel assembly. Here is the guide for it and the part is available at places like this as well as many others. Hope this helps, good luck.
このアンサーは役に立ちましたか?
tnx I have just one question does this work http://www.aliexpress.com/item/Best-Qual...
mutaman, yes it will. Did you notice that the link points to a lot of 10 pieces:-)? I got a couple of assemblies through aliexpress until I finally ended up with a good supplier. Contact Lynne Lin on Skype xinxintech11 from http://www.hcqs.cc/ and see if they can give you a good deal.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 209
2 件のコメント
this happend to me and i had to get a new phone. you can't fix this.
averi carroll さんによる
mutaman さんによる
