メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
締切られた回答
I've got some battery problems after change the Home Button
Hello. Soon after I fixed the Home Button, my battery began to fail. To charge it, is consumed much more time than before. The battery, which previously lasted for 6 hours, today has duration of 2 hours.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I would double check and make sure that the home button is seated in it's slot on the dock port flex correctly. Since it is attached to the same part of the device that controls charging maybe you have a short there. While you have it open also look well to make sure that nothing else on the dock port flex cable is shorting out. If the phone is generating more heat than normal this is usually a pretty good indicator of a short.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 53
