My keyboard has a problem
Hi! Something spilled on my keyboard.The letter n and space is hard to use.What should I do?
you can remove the keyboard from the laptop and put in a sonic cleaner. If you do not have one available try 99 percent isopropal alcohol. Allow to dry before reassembling. If no luck after a good cleaning you will need to replace the keyboard.
このアンサーは役に立ちましたか?
What do you mean remove the keyboard from the laptop?
follow the guide provided by ifixit. Get your screwdrivers and disassemble the laptop and remove the keyboard. it is nothing more that a piece of the Macbook puzzle. It can be removed and cleaned thoroughly.
alright thanks! I'm a bit scared on disassembling my laptop so I'll go to the Mac store tom and let them do it. If they say that i need to replace the keyboard without even checking it first, i'll do it myself. Thanks so much i'll update you asap :)
no problem. I hope it works out in your favor. Have a good one
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 127
