メインコンテンツにスキップ
Samsung Galaxy Note IIは、大型ディスプレイと一体型自己記憶スタイラス用に最適化されたソフトウェアを組み合わせたスマートフォンでとして知られています。
211回答 すべてを表示
Why won't my galaxy note 2 turn on?
I rooted my galaxy note 2 and downloaded an app and now all it does is say 4g lte Samsung galaxy note 2 over and over. It acts like it is going to turn on but then it goes back to 4g lte. I have took the battery out and tried to restart it, I have tried manually rebooting it and nothing works! Please help me fix my phone please!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 42
1件のコメント
first try to reset your phone looking the way here
さんによる
コメントを追加
21件の回答
最も参考になった回答
It's possible you have a faulty battery.
I was convinced my GN2 was a write off. It just showed the gn2 splash screen for a few seconds, before restarting and doing the same thing every 10 seconds. This was without Mains connected. Battery didn't enter my head because even though the phone is over 18 months old, battery life has been good - 6-8 hours.
Plugged into Mains, I got further, but not much. The phone would start to load, but would often restart during this, and would also often just turn itself completely off and show the green battery screen. Occasionally I'd get right through to the home screen and could use it, but every few seconds / minutes it would suddenly drop back to the sim pin screen, and would still occasionally reboot / turn off. It was also doing strange stuff like forgetting my wifi key or reporting corrupted files on the SDCard.
I suspected the battery at this point, but was unable to prove anything without a different one to try. All I knew was that it wouldn't start without Mains, was still flaky with Mains, and would turn off as soon as I pulled the mains out. The phone won't turn on at all if the battery isn't present, ie won't run on Mains alone.
Turns out not all chargers are created equal, and I'm not just talking about amps. The charger that shipped with the phone, while powerful, appears to charge with a variable pattern, ie high power for a few seconds then low power. If it's quiet, I can hear the circuit buzzing, and changing in intensity. I've found that with a dumb 0.7A Nokia charger that the phone is completely OK, as long as it's connected. Now that the phone is stable, I've been able to monitor the battery more scientifically, and I've found that while it reports 100% charged, it still turns off straight away when I pull the plug, and if I plug in and boot up right away, it shows 10% charged, and charges very quickly (from 10% to 70% in 25min).
So, in summary, it looks like a suddenly dead battery, and a charger with an unhelpful charging method, are responsible for a lot of strange behaviour. I've got a battery on the way, and I fully expect it to restore my phone to full performance.
Just don't discount battery as a possible fault, and DO try a variety of compatible chargers, is all I'm saying. Hope this helps someone, if not the OP.
Cheers
Shannon
このアンサーは役に立ちましたか?
スコア 7
1件のコメント:
Thanks a bunch for your help.
さんによる
コメントを追加
Hello Anthony,
So the good news is unless you were messing with Xposed or a similar program your phone ISN'T bricked. However to better answer your question I have a couple for you.
Did you install a custom ROM or a custom recovery simply just root it?
Also the best method you can try is to turn your phone off, hold the power button, home button and volume down until the warning screen comes up. Press down to cancel then hold volume up and the home button while booting up but release them once it vibrates and shows the SAMSUNG logo. If this doesn't work please reply to my question and I can help you further! If it does help please aide to my reputation and score!
Hope this helps!
このアンサーは役に立ちましたか?
スコア 3
10 件のコメント:
What do you mean by a code? A password to enter the phone?
さんによる
Hello Donley I tried to upgrade my Samsung Galaxy Note to android 4.4. I downloaded all the files which was needed as quoted in this forum
http://rootgalaxynote.com/galaxy-note-re...
but when i installed CWM Recovery v6.0.4.5 and tried to reboot, it just shut off and won't turn on again. I took out battery and done those holding buttons method but to no avail. Can u please help me? I'm really worried.
さんによる
ok this worked for me (holding the power button, home and volume down button) so will my phone turn on now everytime?
さんによる
same prob thanks plug into mains held 3 buttons up pop message saying critical system break down press up vol key too download recovery its downloading now or is it
さんによる
i have a phone that wont turn on past the samsung screen what do i do?
さんによる
5件以上のコメントを表示
コメントを追加
my phone doesn't turn on. when i put it on charge it doesn't indicate it is charging.
i tried different batteries.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
After shutting down my phone it won't turn on. What should I do?? I'm in desperate need of help!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
So my phone was stuck at the Samsung Galaxy Note 2 screen so what I did was hold down the home,power, and lower volume button then it gave me this warning screen. And I pressed the upper volume button and now it is on the downloading screen. I have been waiting like 30 minutes and it still is at the screen. My question is how long does it normally take and is it frozen?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
hey guys , if your phone doesnt go through the logo phase than the your firmware is broken.. google for - "how to flash stock rom note 2 " . you will find your solution.
さんによる
コメントを追加
If it asked for a code, so what should i do next?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my Note doesn't want to swith on but as soon as I put it on charge, my flashlight goes on but the fone doesn't want to. can someone please help me
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello my GN2 shows samsung logo but does not boot. After a while it was no longer ahowing the samsung logo. I remember the phon was working a day before but battery was low and i saw an advert to save battery and clicked to download. And on the following day it was only showing samsung logo and battery charge comes on but was not appearing to charge, Please help me. My phone was obtained less than 2 years. Lionel
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Same things were happened to my GN2, hope someone will help
さんによる
コメントを追加
gn2 goes to the tmobile 4glte screen. it will stay at that screen til i either remove the battery or it dies. i dont want to master reset my phone seeing that it has very keepsake photos on it. what can i do to fix this
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
good day,
my galaxy note 2 wont open.
i left it when i sleep with minimal battery but not in red.
then when i woke up, its off & it wont open again.
i replaced the battery with my spare full charged battery but it still wont open.
i tried holding the power button but it wont open.
i tried holding the volume key dowm, home button, & power button for a minute but nothing happened.
i also tried holding volume key up, home button, & power button but nothing happened.
its not rooted.
the last thing i did was uninstall some apps.
play games & facebook turn off wifi then sleep.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Same problem here. Im in the office didnt notice my battery i low then when i charge it in the house it didnt open
さんによる
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i switched on my developer options and tick the usb debugging . when i switched off my phone and i try to roots my phone. so i pressed volume up , home key button and power button and it came out SD Card Checked. i waited less than 1 minute then i took out the battery of my phone cause it taking too long. when i put my battery back in. i cant switch my phone on . Please help me fix my phone as soon as possible !
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello guys,
I have SGN2 and I turned it off so I can charge it, after 3 hours when I go back to take it off charge and switch on I find out there is Blue LED and as we know it is normally supposed to show the green battery on a screen when it is full charged but now it shows nothing. I took out battery and put in again and try manual rebooting but my phone doesn't turn on. When I put it on charge it doesn't indicate if it is charging. I tried to remove SD and SIM card then I reboot it again manually but still there is nothing.
Please share with me any idea what I can do to turn it on.. TNX GUYS
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I am experiencing the same issue with mine. Also a non-rooted phone.
さんによる
コメントを追加
i have the same problem too u know
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Why my phone won't come on I bought a new battery and it want charge either
Update (09/14/2015)
My phone want charge or come on and I bought a new battery and it still not charging
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
it could be that you need a new USB board (the part that you plug your phone into).
さんによる
i have the same problem, put new charging port in and new battery and still won't come on.
さんによる
コメントを追加
My Note two charges only and doesn't switch on.
It dies completely when i remove it from charger
I tried the 3 key method and it stays on the samsung logo and doesn't change.
Please help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You have to install note 2 stock room from http://www.sammobile.com/firmwares/ and install it on you Phone with Odin.
There is plenty of tutorials on Google that shows how to use Odin.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have a sgn2 and my phone was okay today and ended up been stuck on the samsung galaxy logo and wouldnt switch off and my partner has done a reboot and now its downloading, hopefuly it is sorting itself out.
will keep you updated as to what is happening with it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My samsung note 2 needing a charging port so I ordered it it did work cuz when I have it charged u can see battery to n screen were it is charging but it wont turn on, can it be that the power button don't work. What can it be
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
everybody is $@$*!&%& around in here . no one has the solution to anything!!! useless
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
s h i t t i n g
さんによる
コメントを追加
Try flashing your device with Samsung Odin. After flashing stock ROM problem will be solved.Download Odin here.https://odindownload.com/SamsungOdin/
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Anthony Shepherd さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 28
過去 30 日: 63
今までの合計 82,530
