Why did my screen turn black?
I pulled my phone out of my back pocket and randomly there was a crack on the inside of my phone I turn it on and half the screen is back, is there any way to fix this? please respond as soon as possible.
thank you.
Hi there seen this happen to a Friend of mine with a s4 the pressure of the jeans when bending or sitting down has put pressure on the front screen and damaged it most likely busted the lcd..
A new screen will fix this but is expensive that's why I always tell people to buy iPhones cause samsungs are to dame expensive to repair
このアンサーは役に立ちましたか?
I have the similar problem. I pulled my Samsung Galaxy S4 phone out of my back pocket and randomly it turned it on black screen touch screen is not responding as well. I pressed any buttons( the home button, the volume buttons, the power button) it wont bring the screen back up again. I pulled several times the battery from phone and waited 30 sec to 1 min to plug it but no improvement....Still not working! Can anyone explain me why?
このアンサーは役に立ちましたか?
the same thing has happened to me but i don't know how it happened i had my phone in a purse and it was fine then i noticed a black ring on the screen so i shut my phone off and restarted it and it has been like that for 3 days now but.. everyday the screen gets worse and while i'm at school i leave it at home and no one touches it but the screen just keeps on getting worse and worse to the point where i cant even use my phone anymore its so bad and its so discolored.... but the thing was that it was just sitting in a purse there was no pressure added to it at all but also i was able to use it but then after like maybe an hour it started being all weird and wouldn't let me use it anymore i'm really confused on what happened to it
このアンサーは役に立ちましたか?
I still have not figured out why the LCD stopped working after the touchscreen recieved a vert small fracture in the glass. The crack didn't even reach the surface. Everything else appeared to be working fine, lights, sounds, power on/off.
このアンサーは役に立ちましたか?
solition chergement interrompu températeur de la batterie trop faible
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 12,602
