メインコンテンツにスキップ
The HTC One X is the first HTC phone to be equipped with a quad-core processor, released in April 2012.
41回答 すべてを表示
My HTC One X screen has just gone blank...
My HTC One X was working perfectly fine but then suddenly the screen went black. I tried connecting it to the charger but the red charging light wouldn't come on. I also tried ringing the phone but nothing happened. I tried holding the power button for about 15 seconds, still no response. The final thing I tried was to connect it to the computer to see if the computer would detect the device however the computer didn't. I don't know what else to do, HELP?!?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 13
8 件のコメント
keep holding the power button and the volume up it worked for me
さんによる
Thank you , Yasa. A great fix. Did the trick !
さんによる
@Yara Mansour I love you rn I you are my life tbh
さんによる
This totally saved me! Thanks!
さんによる
hey guys it worked forme too. since yest night ithad this issue suddenly turned blank. when called said switchoff. but could get whatsapp call, but could not attend. alarm was ringing but could not slide to off. but this trick worked thks very much
さんによる
3件以上のコメントを表示
コメントを追加
6件の回答
最も参考になった回答
Mine blanked too! This twist thing (below) actually worked:
http://www.htconeforum.com/forum/htc-one...
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Great!! Twisting got my black screen problem solved! Thank you for sharing :)
さんによる
i have the same problem , Adinda Adinda how solved black screen problem
さんによる
コメントを追加
It seems your phone died for broken motherboard or battery, you need to send for professional check.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Are the local phone repair shops fine? And do you know how much they will charge to repair it.
さんによる
コメントを追加
You have what's know as the black screen problem, ( I have too) there is a fix but it involves taking the phone apart and putting a bit of paper between a ribbon cable bend. I'm looking for the fix again myself. In the meantime I bought a new phone LG G2, (good phone recommended) I'll post back here once I find the fix, but it's not for noobs.
Found it: http://www.htconeforum.com/forum/htc-one...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
hameed_kakar2003@yahoo.com
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
mine was taken back to china.apparently not even flashing wold help and no one knew wat the !&&* was going on.am still waiting for my phone
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How to fix htc one x overheating? Touchscreen sutting down automaticly
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Haroon さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 12
今までの合計 42,499
