メインコンテンツにスキップ
Samsung's fitness-oriented smartwatch, featuring a curved super AMOLED touchscreen display. First released in April 2014.
34回答 すべてを表示
My screen is freezing/lagging. How do I fix this?
The screen on my Gear Fit occasionally becomes unresponsive and lags or freezes. Either the software is unresponsive, or the touchscreen itself cannot pick up my inputs. How can I fix this problem?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
選択されたソリューション
Hello Nathan,
Issues with lagging and freezing can come from overtaxing your device. If you notice that your issues worsen after prolonged use of your device, this is most likely the issue. If you're touch screen is responsive enough try closing all running apps and programs. For alternative solutions, check here for our troubleshooting guide on screen lag.
If your problem persists with no apps running, it's more likely to be your touchscreen is not responding to your input. Check to make sure your fingers and screen are clean and clear of obstructing substances (screen protectors may be causing the issue). Additional information regarding this is posted here as well.
Let us know if your issue requires further assistance.
Kyle
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I am having the same problem with mine and it is not the screen
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nathan Powell さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 8,264
