How to fix a broken iPad mini retina screen
I have a broken iPad mini retina screen. How could that be repaired and what cost. Apple Store cost is 249.
I'm not quite sure exactly what you mean---
If you mean you have an iPad mini retina version device that currently has a cracked touchscreen, then you can either order a screen assembly and follow a guide to try a DIY screen replacement, or send it out for glass screen replacement service.
If you mean how do you repair a broken LCD itself--that is generally not possible, folks just order a new retina LCD screen as a replacement part.
jessa
このアンサーは役に立ちましたか?
It's more difficult than full size iPads. A lot of tape needs to be transferred and the LCD needs to be carefully separated. Any DIY kit should be sure to include a digitizer that does not require soldering.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 4,524
