Help! Kickstarter won't budge!
The kickstarter will not budge a bit when I try to kick it over, what should I do?!
この質問は役に立ちましたか?
この質問は役に立ちましたか?
the suzuki fa50 is has a built in safety release mechanism on the kickstart gear. The kickstarter will not engage without the rear brake lever depressed.
このアンサーは役に立ちましたか?
Not that you need to know this Tim, that is correct. I had 1 of these in the early 1980's
surely that would have been illegal..lol
It could be jammed--sometimes if you put it in gear and push it things will free up. Otherwise you must disassemble the mechanism to find and clear the bind. Ralph
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 1,587
2 件のコメント
Is it used often? or has it been left unused?
Chris Green さんによる
I really don't know how long it's been sitting. I think it's an automatic as well so how would I get it in gear?
thegaragequeen22 さんによる
