メインコンテンツにスキップ
”PS2”として知られた第6台目のビデオコンソールは、Sonyによって2000年3月に日本国内で発売されました。米国では2000年後半に発売されました。モデル番号はSCPH-30000です。このデバイスの修理には一般的なツールが必要ですが、修理は技術が必要です。
195回答 すべてを表示
Why does my PS2 show a 'Brwser/System Configuration' screen on some ga
My Playststion 2 opens to a screen that says 'Browser/ system configuration' screen on some of my games. It will not load game when this screen pops up. It also says to use a Playstation or Playstation format game. What does this mean??
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 14
10 件のコメント
When i play any game nd when the game is start so my screen pop up and in the bottom it shows black screen nd the game is pop up i play on half tv nd the half tv is black plz tell me any solution
さんによる
It's because your disk tray is too high up put pressure onto the top of the tray with the disk in and lid closed and it will load up. If it stops when you remove pressure keep something heavy on it
さんによる
@Baconchops09 thank you!!!!! I have thrown away 4 ps2s and was getting ready to toss this one! Ur 'trick?' Worked! Thank u!!!!!!!!!!
さんによる
So i turn on my ps2 and when i get to the home screen all i mean ALL the words are pink, blue or gray . Also when i get into the game the words are so out place that you can't even read it. Someone please help me.
さんによる
So i turn on my ps2 and when i get to the home screen all i mean ALL the words are pink, blue or gray . Also when i get into the game the words are so out place that you can't even read it. Someone please help me. by max
this is maybe a BIOS corruption and it means that your device is pretty f..ked up
さんによる
5件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
Are you trying to play copied games ?
if not - it's possible that the laser has problems to read the games.
most people are saying thet the laser is defective and needs to be replaced.
but i had a few ps2's with laser problems and all of them were only dirty - the dust is "burnt" on the laser. i've cleaned them with a slightly wet microfibre cloth and that was it - the are all running without any problem
このアンサーは役に立ちましたか?
スコア 10
8 件のコメント:
Then it shows READING DISC, DISC CANNOT BE READ
さんによる
I'll retry doing that.. But isn't a microfiber cloth gonna get all of its fiber sticker to it like dust as well? Thanks
さんによる
PD के game nahe dekha ta hai serf browser or confregration dekhata hai please help
さんによる
I used to play a 4 disk game on my ps2 with no problem and had saved 6 files on my memory card. I lost the game and bought a new set of it, but it won't let me save or load. The message says memory card not inserted. I tried it with my tekken 5 game and it works just fine. What do I do?
さんによる
Please it is a new one a man in my area told me that my pile needs configuration please is that true
さんによる
3件以上のコメントを表示
コメントを追加
Try to buy a new MEMORY CARD. Some ps2's are starting the console from memory cards. Your system configuration in memory card might be corrupted or deleted.
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
pls I use to play my ps2 with memory card and I travel and come back I try to play my ps2 again but is not reading my memory card it only shows me browser/configuration settings pls someone should help me pls
さんによる
Put in a memory card and everything worked perfectly.
さんによる
My PS2 shows only browser/system configuration what can I do
さんによる
I unscrewed the casing and wow the amount of dust it had gathered just by being in a carrier bag tucked away, I only use when I work away & not used since last November. Would be easier to get a Henry vacuum up against the fan at the back and let the vacuum do it's magic. PlayStation works fine now.
さんによる
コメントを追加
回答を追加する
wade webb さん、ありがとうございました!
統計データ:
過去 24時間: 30
過去 7 日: 211
過去 30 日: 1,059
今までの合計 165,577
