メインコンテンツにスキップ
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
430の回答 すべてを表示
broken disc tray. replacement whole disc tray
my xbox 360 disc tray is 100% broken parts missing i need a whole new one i wanna know if i buy a new one of ebay or what ever if you'll show me how to fix it plz and thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1回答
最も参考になった回答
You can't replace the drive as a whole, because it's circuit board is keyed to the console's motherboard. However, if your console isn't under warranty, you can open it, find the make and model model of the drive (Microsoft uses several different brands of drives in their consoles depending on when/where they were made) and order an identical drive on eBay or another site. Then, you can use parts from the working drive to repair your drive or you can swap the drive control boards and just plug and play (This tends to be more difficult). If you tell me the model of the drive once you open the console, I can assist you further with the drive repair.
この回答は役に立ちましたか?
スコア 1
コメント:
its a dg-16d2s philips & lite-on, this is what i found on ebay
http://www.ebay.com/itm/370963776999?ssP...
による
Okay, the board swapping procedure for that drive isn't too bad. There are a few ribbon cables that need to be removed and some wires that will need to be de-soldered and then re-soldered. This video documents the process pretty well also. If you feel comfortable doing that, go ahead and order the replacement. Since you have already opened the console and looked at the drive model, I'll assume you can figure out how to remove it. I believe that the drive comes apart by removing 4 small phillips screws on the bottom of it. Let me know if you have any more questions, good luck!
による
コメントを追加
回答を追加する
Nick Mays さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 423
