メインコンテンツにスキップ
1.83 GHz Core Duo or 1.83, 2,もしくは2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201回答 すべてを表示
No light on screen, fans all run high?
The computer is the Apple iMac, model 1195. I replaced a bad screen (the typical colored lines flooding the screen issue with this model) and now when I power up, all the fans, the HD, and the ODD, all run at high speed, and there is no light on the screen...totally black. This happens whether or not memory is installed, so I'm assuming it must be logic board or power related?
I have tried reconnecting everything that I disconnected during the install, and no change. Are there any troubleshooting tips or guides to help isolate the problem?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
First hook it up to an external monitor to see if it is generating a video signal. Examine the logic board capacitors (cans) for swelling and/or corrosion. Are you getting a normal start up tone? Did you get any beeps when you removed the RAM?
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Thanks, Mayer. I don't have a external monitor cable, but I will get one and give that a try, although I don't think it's even getting to the point of video output. When the power button is pressed, all three fans start up and run at the highest speed. There is no startup tone and this happens even with the memory removed. With memory removed, I should get beeps at least.
さんによる
Open it up and examine the diagnostic LEDs on start up and let us know what you find. You are correct, it's to early for the external monitor test.
さんによる
I would "love" to be able to examine diagnostic LEDs, but I have been unable to find any manuals or reference that shows where they are. I have it opened up and can not find any LEDs anywhere. This is a late 2006 model A1195.
さんによる
コメントを追加
最も参考になった回答
Ron, just to help you out with the troubleshooting:"
Diagnostic LEDs
The iMac (17-inch Late 2006) has three built-in diagnostic LEDs and a front power-on/sleep LED on the main logic board that can help you to troubleshoot the computer.
To Access the Diagnostic LEDs:v
1. Follow the take apart instructions to remove the RAM access door, front bezel, and lower EMI shield.
2. Locate the SO-DIMM slot and LVDS video connector. The three diagnostic LEDs 1, 2, and 3 are located to the left of the battery and under the SATA cable. Note that the LEDs are marked 1, 2, 3 from left to right, as show below. An additional front bezel LED is located in an opening at the center of the right speaker, as shown below
LED #1
• Indicates that the trickle voltage from the power supply has been detected by the main logic board. This LED will remain ON whenever the iMac is connected to a working AC power source. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power source is disconnected or the power supply is faulty.
LED #2
• Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED #3
• Indicates that the computer and the LCD display are communicating. This LED will be ON when the computer is turned on and video signal is being generated.
Front LED
• Indicates that the computer has power but no video signal (e.g., the computer is starting up or the display has entered Sleep mode, turning off the video signal). This LED will pulse when the entire system has entered Energy Saver mode.
このアンサーは役に立ちましたか?
スコア 2
13 件のコメント:
Thank you oldturkey03! I found the 3 diagnostic LEDs hiding under a piece of black tape, just to the right of LVDS connector. This is a bit different from the graphic you provided, but I expect they provide the same function. My serial number says it is late 2006, though.
Anyway, here are the results:
LED1 comes on when the AC cord is plugged in. (normal)
LED2 comes on when I press the power button. (normal)
LED3 does not come on. (no video signal?)
LED4 comes on with power button, dim at first, then bright, and stays on.
So....does this indicate a logic board problem with the video? Any tips for a reset or workaround there? Your help very much appreciated.
さんによる
I'd hook up an external monitor. If that shows Video, you know that your video circuitry is functioning and the error is with your LCD. If it does not work, than the issues are with your logic board (video circuitry.)
さんによる
Again, your advice is appreciated. No video with external or internal monitor. Since the fans all run at high speed, there is no startup sound, and symptoms are the same with and without memory, I suspect it must be logic board or video circuitry related....perhaps something heat related since the fans start up and stay at high speed? Do you know if there is a separate video card, or is it a chip on the motherboard for this model? (Late 2006 iMac a1195) I am more familiar with PCs, and there is a video chip solder reflow issue that can cause similar symptoms on those mother boards.
さんによる
First, I think I have inadvertently started two questions by opening a post specifically for iMac Intel 17". Sorry, I am a newbie to the forum and will be glad to close one of them as soon as I figure out how to do that.
さんによる
Ron, I think if you click on the blue Actions link on the right side above your question, it may giver you some option s to archive that particular question. Anyhow this is what Apple suggest for symptoms similar to yours:"
No Video, Boot Chime heard, White LED ON (Symptom 2)
The iMac (17-inch Late 2006) will turn on, the boot chime can be heard, a white LED appears on the front bezel and sounds from the fan or drive activity can be heard, but the display has no picture or color.
1. Check if the computer is sleeping. Press the space bar to wake the computer from sleep mode.
Did the computer wake from sleep?
Yes: Put the computer to sleep from the Apple menu and wake the computer again to test.
Check Energy Saver setting to see when the computer has been designated to sleep.
No: Continue to next step.
2. Reset your computer’s PRAM (Parameter RAM):
If y -- our iMac is on, turn it off by holding the power button until the unit powers off. You should hear the fans go quiet.
-- While the computer is off, with your left hand, hold down the Apple key, the Option key next to it, and the letter “R” key on the keyboard. When you have these keys all pressed down, push the power button with your right hand and then quickly move that hand to hold down the letter “P” on the keyboard. Keep these four keys pressed while the computer starts up.
-- Make sure you hold down the four keys (P - R - Apple - Option) while the computer is
starting up. When you hear the computer’s start up chime for the second time, you can
let go of the keys on the keyboard
-- If you didn’t hear at least two startup chimes, go to the top of this section and begin
again. It’s important that you hear two startup chimes when performing this procedure.
This indicates that you have successfully reset the computer’s PRAM (Parameter RAM).
3. Does the computer display video after successfully resetting the computer’s PRAM?
Yes: Restart the computer from the Apple menu and make sure the computer is now
working correctly.
4. Make sure the machine is powered off; power off the machine by holding in the Power Button on the rear of the machine. Turn on the machine. Observe the white LED on the front bezel during startup; it should go out after a few moments. Did the LED go off?
Yes: If the LED went off, this indicates that the main logic board has communicated with the LCD display for video signal and your main logic board should be good. You can confirm by connecting an external monitor and checking to see that you have video out. Go to Step 7.
No: Continue with the next step to reset system power management (SMC).
5. Follow instructions in the “General Information” chapter to reset the SMC. Does the computer display video after successfully resetting the SMC?
Yes: Press and hold the power button until the computer powers off. Start the computer again and confirm that front LED is reliably going off. If the computer still has no video but the LED is reliably going off, continue with step 7.
No: Go to the next step.
6. Unplug the iMac and remove the SDRAM. Replace with known good SDRAM. Plug the iMac back in and power the unit on. Does the front LED go off after a few moments now?
Yes: Replace the original SDRAM and test again. If the front LED does not go off with the only the original SDRAM installed, replace the SDRAM. If the LED is now reliably going off after a few moments, but yet you still do not have any video, go to step 7.
No: If the LED remained on, the main logic board is not communicating with the LCD panel to generate video. Replace the main logic board.
7. With the LED going off, you may have a No Backlight condition or an LCD failure. In a dim room, turn the display at an angle to you and look closely at the display. Is the display completely black or can you see a dim, purplish light or glow to the display?
-- Completely black: Replace the inverter
-- Dim purplish light or glow: Replace the LCD panel
Now, I realize you already replaced the LCD, so you are coming close to the logic board being at fault. If the video chip would fail/ have failed the behavior is usually somewhat different. More like distorted graphics, plenty of colored boxes on the screen etc. but it is a possibility.
さんによる
8件以上のコメントを表示
コメントを追加
この回答は他の質問に帰属しています。
So, I received the replacement logic board today, installed it, and now the iMac starts up as expected. I still have a video problem, but that is because the replacement LCD screen I ordered is bad. At least the old one still works now, multi lines and all. So somehow I must have injured the logic board when I originally installed the replacement LCD screen. I am definitely more careful handling all the parts now. Learned a bit about troubleshooting iMacs, so thanks again for all the communications. Guess I'll close this post. Thanks. Ron
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Ron, good job with this question. It was a pleasure and best of luck with your iMac.
さんによる
コメントを追加
回答を追加する
Ron さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,629
