メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2521回答 すべてを表示
Please help! Battery iPhone 5
Hello Guys,
i got a problem with my iphone 5G. the iphone works perfect but the battery drain is very high and after the battery is empty the iphone stays off but after a while the battery doesnt work anymore. iphone turns on and off normal. i changed the battery same issue. high battery drain (12hours) without using it and after battery is empty battery wont work anymore.
any suggest?
thanks in advance kind regards
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
ever gotten water in it?
さんによる
never -ever gotten water in it
さんによる
コメントを追加
3件の回答
最も参考になった回答
Sounds like damage to the motherboard either by pry damage or dropping it
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have same problem with my iPhone.i think its problem with power management ic. If the phone has not been opened send it back to apple with original things and they should sort it out.
Update
I got a new battery charged it my mates phone and put charged battery in my iPhone it worked as long as I didn't let battery die would charge up aswell but once battery died it just would not boot. I just bought 2 new batteries but its just not booting up nothing just dead.am hoping to reflow power management ic.but I'll try doing what old turkey said first though let you know outcome. But if you have original things in it send it back to apple doesn't matter if it is out of warranty.there has been lot of problems on ios 7 with battery so they should sort it for free worth a shot
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
it is out of warranty. i can't get a replacement. already called apple.
what is the solution if it is the "power management ic" or what else i can do? what did you do with ur i5 with that same problem?
さんによる
コメントを追加
DanielAA, before going to check your PMIC, I would go and replace the lightning connector. It is entirely possible that your battery is just not charging. If that does not work, then you could check the charging circuit out. It is always possible that the Charging and USB Control Chip CSD75202w15 has failed or needs a reflow.
Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
DanielAA さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 444
