no connection to antenna to base but will charge
unit will charge and playback stored media but get no signal. is the bottom part replacable or fixable
There is a little brass (thing) on the bottom of antenna post and after I switched to another unit I realized that that little brass colored thing was stuck it the dock and when I put another receiver on dock it pushed up the little post into unit making it not work. I have never had a unit apart so I was not sure if there was a way to fix it. Sorry as it is a little hard to explain and I did not go to Harvard. Thanks for any help!!! Frank
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 324
Has anything happened to the device recently?
Gary さんによる
