メインコンテンツにスキップ
A tablet developed by HP in 2011 running the webOS platform. Boasts a 9.7" display, and is available in 16 or 32 GB. Repair is straightforward, but requires time and persistence.
56回答 すべてを表示
poor wifi signal on HP Touch Pad
After replacing the LCD screen on my HP touch pad, the wifi signal is poor. It is good if I am right beside the router however the further I get away from it the worse it gets until there is none. I used to get a signal in the livingroom and now I don't get anything. Could I have damaged one of the antennas and if so which one -the upper or lower?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
I would try resetting your wifi router or try boosting the signal on your router to see if that doesn't help
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
cindy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 209
