メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
3338の回答 すべて表示
No sound and voice during call but dictaphone, skype ... work
Hello,
I get an iphone 5 which is fully working except I can't hear someone and nobody can her me during a call however speakers and the micrphone work great during other app (like skype or dictaphone...)
What is the problem ? => motherboard (I think it's like on some iphone 4; some pins on a chip are desolder ?)
Thanks
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
up please ;)
による
コメントを追加
iPhoneのバッテリーキット
Only $29.99
Buy Now
iPhoneのバッテリーキット
Only $29.99
Buy Now
3回答
選択されたソリューション
bigboss59400, before you even think of changing any IC on your logic board, replace the dock connector first. You are further confusing the issue by changing the logic board between different cases etc. The likelihood is far great that your dock connector mic has failed than an IC on your logic board. It will require special tools and special skills to reball an IC and would be a very difficult undertaking for the average DIY'er.
Update
Step 15 of this guide shows it surrounded in teal color. That is U21
この回答は役に立ちましたか?
スコア 2
コメント:
WHy replacing the dock connector ? Since I already do that; I take an iphone 5 FULLY WORKING and put my motherboard on it and it's the same.
That's why it's seems to not be an issue from mics and speakers....
I know it's difficult but I know someone who have these skills and tools so tell me what IC I should replace or maybe you have a better idea
THanks for all
による
Thanks for your update
So now I'm trying to find a brand new chip which I think will be very difficult anyway
Problem is "solve"
による
コメントを追加
If no1 can here you during a call it's the microphone that's attached to the dock connector but if you can't hear them either then it could be a problem with the motherboard just like in the iPhone like you sayed.. Did this problem of the two parts happen at the same time?
この回答は役に立ちましたか?
スコア 1
コメント:
Tks for your reply
But skype is working fine thats why I thibk it's a motherboard problem...
I will try to put it in a working iPhone case
Can you tell me which chip control these functions so that I will desolder it and resolde a brand new one
Thanks for all
による
I no you say skype works but it works with the upper mic not the bottom one..
I wouldn't be to sure in the symmetrics of the iPhone but there is plenty of people on here that do
による
So since I have a good friend with an iphone 5, he was agree to dissasemble is working one to put my motherboard on it however after doing this my motherboard doesn't want to read a sim card (I set the clock but no improve)
Also waiting for info about the chip which control voices during call...
THX
による
Time and date set to auto in setting and make sure time zone is correct aswel.. Then connect to wifi it will automatically set time and date for you..
Turn phone off and on you will regain service
による
Thanks for your reply
Normally I do that but it was not working this Time so I restored it and it worked anyway.
Putting my motherboard on his complete working case is not working too... So my motherboard seems to be damage ... So what chip do I have to change ?
Thx
による
表示する 2 他のコメントを
コメントを追加
I also need to know where the sound ic is on iPhone 5 board , I have same issue , wondered weather heating or padding the ic will sort problem like it does on the iPhone 4 as it may have just come loose after a drop
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
bigboss59400 さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 4,256
