メインコンテンツにスキップ
Mid 2006 / model number A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor.
518の回答 すべて表示
Broken keyboard ribbon connector. How to power up?
Hi,
I've tried to repair a broken MacBook but I've also broken the keyboard ribbon connector. Now the laptop doesn't power up. Is there another way to power up it?
Thanks in advance for the answers.
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
iPhoneのバッテリーキット
Only $29.99
Buy Now
iPhoneのバッテリーキット
Only $29.99
Buy Now
3回答
選択されたソリューション
Hi, If the problem is that you have broken the connector on the logic board the most reliable fix is to replace the logic board. However some people have had some luck making as good contact as possible and taping the cable in place. Sometimes it works - sometimes it doesn't. If the problem is the cable itself you have an easier and less expensive solution. Replace the cable.Good luck. Ralph
MacBook Upper Case Cable
この回答は役に立ちましたか?
スコア 2
コメントを追加
yes - there is another way to start the MacBook
look at the picture - above the middle yellow box - you can read pwr btn - the actual contacts are left from it - left from the 490 - there are 2 contacts, separated with a thin white line - thats the "power button" - short the contacts with a small screwdriver and the MacBooks starts without the topcase attached - but thats only good for repair or modding issues - not for "regular work" - and of course - take care not to touch anything else with the screwdriver - except you love the smell of burnt electronics in the morning *bzzzzt-bzzzzt* ;-)
この回答は役に立ちましたか?
スコア 2
コメント:
only a question... the contacts are the two on the left you have marked? because I don't understand where I have to lie the screwdrver..
による
I updated the picture for you. the original was from ifixit. i think you will find the contacts now.
による
コメントを追加
wait hang on are you ment to just poke the white line inbetween the bits of solder i think i have the same prob my keybords not working wamt to make sure it is only the keyboard before i buy another one
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Carlotta さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 6,816
