How can I improve my battery life?
My battery dies after only a few hours of use, much faster than when I first got the phone. How can I improve this?
It depends on what is causing your battery problems. If it's the charger itself, you may want to check the connection between the charger and the phone, or replace the charger all together.
Another cause of short battery life is an improperly functioning battery. Batteries, especially on older phones, weaken over time. Replacing the battery may get you the extended use you want.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 66
