Can I add a bluetooth card to this machine
there is a bluetooth port but no card blue tooth ant sign above F1 but no function switch icon at f2 or anyware else can I still upgrade this machine?
robert, enter the service tag from your computer on this site. It should provide you with a list of components and options for your individual computer. Hope this helps, good luck.
このアンサーは役に立ちましたか?
Isn't a bluetooth already there in Dell's build up. I have a Vostro and bluetooth is built-in inside. Latitude is an old model, I suppose, you have to look into Dell Store for sure or I think a local technician may also help you out.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 424
3 件のコメント
the laptop didnot have blue tooth when i got it i did inspection of it and it has the port just want to know if i can upgrade it
robert さんによる
Do you have the slot labeled WPAN/UWB/FCM on your motherboard?
oldturkey03 さんによる
yes port has small blue wire at it
robert さんによる
