Service battery after cold temperatures?
Hi, I have a 2006 macbook with a aftermarket battery that I got off amazon for $20. The battery works perfectly when I leave it in warm temperatures but when I bring the computer outside (even when it is off) it looses its maximum capacity from 5462 mAh to 4021 mAh. Its factory maximum capacity was 5600 mAh.
Also, the macbook shuts off at 25% battery no matter what and it will not turn back on without the magsafe adapter.
Any ideas or explanations?
Thanks, Ted.
この質問は役に立ちましたか?
3 件のコメント
How cold is cold?
oldturkey03 さんによる
from about 20 degrees Fahrenheit to 40 degrees Fahrenheit. Im in northeast ohio so it usually is cold outside at this time.
Ted Mayer さんによる
the battery was manufactured 12/28/13 and has 12 charge cycles on it
Ted Mayer さんによる
