メインコンテンツにスキップ
2008年10月発売。2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duoプロセッサ。
376回答 すべてを表示
keyboard is not responding after small water damage / repair
Yesterday, I spilled a small amount of tea on my MacBook Pro. it spilled mainly around the trackpad area and to the first row of keys, space and commend etc.
I turned it off, ejected the battery, stripped the computer, remove the logic board and removed the keyboard backlight panel and then dried the upper-case with a hair drier.
I also took out the touchpad and gave it a clean. Tragically, I tore the touchpad ribbon upon removal.
Current symptoms:
all systems work per normal except:
  • fans run non-stop
  • keyboard is totally unresponsive
  • obviously trackpad dead but new ribbon is on it's way.
what on earth happened in there? before stripping it completely after a dry, when I booted it up to test the trackpad, after about 20 seconds the volume started to go up by itself and I think random keys were being pressed.
what is my next move?
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
the same thing happened to me , when a leak developed in my ceiling, dripping onto my open laptop all evening. i ended up replacing the keyboard on my late 2006 macbook pro.
rsrsparky
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Matt Rowlands さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 330
