メインコンテンツにスキップ
The GE Profile Tri-Temp is a free-standing water dispenser with an integrated chilled compartment.
52回答 すべてを表示
The power is on but the water won't dispense
Hi, my water dispenser always worked fine until recently. I stopped using it for about 2 years so it was sitting and not being used, though it was plugged in and powered on the whole time. I recently decided to start using it again, but I can't get the water to come out. It did for a day or two after I started using it again but stopped for some reason. I did notice that the reservoir seemed to have an ice "ring" around the inside of it...basically like a block of ice shaped like a donut. I don't know if that's related.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
I'd unplug it and let it come to room temperature for a couple of days. This should reset it and allow it to defrost (if that is ice). Plug it back in and let us know your results.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Matt さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 919
