anyone dropped it in a toilet full of pee?
Everyone describes there stories as dropping it in the toilet but with fresh water, I just finished peeing when my decided to take a dive? You think rice will save from pee? or am I SOL?
It's very diluted acid. I'd treat it just like it was plain water. Or you can reference this: My Laptop was off when my small rabbit wizzed on it. What should I do?
このアンサーは役に立ちましたか?
I'm not sure of it's gonna work so I advice you to but a new phone just in case and make sure it is not a take phone.
I'm not sure if the phone is going to work so just in case buy a new one.
このアンサーは役に立ちましたか?
since it's a five year old question, the point is probably mute now as the iPod is out of date
Hi,
as pee is a mixture of a lot of chemicals, a.e salts, this way its more corosive than pure water. Salt is corrosive on the one hand and makes water more conductive on the other hand. So it's important to get it out a.s.a.p.
So first thing would be to open it up and take out the battery, give it a good rinse in water, then dry it, put it back together and see if it's still alive or not.
このアンサーは役に立ちましたか?
any house hold tools i can use to open it up? I already have it it some rice.. btw might I add I had lots of alcohol in me at the time. could that also make it worse?
Here's what your looking for: iPod Touch
Depending on the generation of your iPod, you will find the right guide to open your iPod.
P.S. Pee is worse enough ;-)
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 18,292
