メインコンテンツにスキップ
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418回答 すべてを表示
締切られた回答
No startup chime or screen power
Early 2006 MacBook had water spill.
Disassembled it and cleaned it but after reassembly the MagSafe light was visible only in a dark room and nothing would turn on.
Logic board probably destroyed because computer was left powered on after it got wet so I replaced the board. Now mag safe light is green and when I hold down the power button I can hear the drive spinning but no chime or screen light!
What to do next?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Well, I found the problem. Bad RAM! Both modules were bad. Could the coffee spill which caused the original problem have destroyed them?
Thanks Lemerise and mackhead3 for your suggestions.
さんによる
コメントを追加
2件の回答
ベストアンサー
Connect to an external monitor - you should see a normal display, if you don't the new board has a bad GPU. If you see a normal display it could be your inverter board, or cable/connector(s) examine them for corrosion and complete proper connection. Generally a backlight replace is a very advanced DIY… easier to replace the screen if the inverter board does not improve things.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
After a logic bord swap it's wise to do a SMC and a pram reset. If the logic board still does'nt boot remove the top case and try to start it directly via the two power pads located just under the fan. You did'nt replaced the liquid spilled top case so it could be shorted even if the power switch works.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I did an SMC and pram reset but no change. I do not see any power pads under the fan.
Glenn Gutshall
さんによる
Glenn- For future reference you posted a Comment in the place where only Answers belong. Please use the add comment link to the appropriate Answer or update your O.Q..
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 168
