メインコンテンツにスキップ
iFixit を楽しむためのヒントとテクニック
26回答 すべてを表示
Where is the add comment link? What is O.Q.?
I was told I put a question where answers should be. But it said to use add comment link in O.Q. -
Where is the add comment link? What is O.Q.? Sorry, I'm confused.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I see an Add Comment link here but not in the question I wanted to discuss.
さんによる
コメントを追加
1 件の回答
選択されたソリューション
ReRe, ifixit is a bit different than most other forums. Here you have the chance to ask your own personal question, and receive an individualized answer. You would use the "Ask a question" tab to the right of the screen which will take you here http://www.ifixit.com/Answers/Ask/iFixit Then you ask your question. If you post a question either as an answer or a comment to someone elses question, it will get lost and you most likely will not get an answer. This is done so that the focus is on answering the original question only. O.Q. possibly means "other question" if you have posted more than one question. The add comment link is the light blue link just above the answers. Hope this explains it.
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
回答を追加する
ReRe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 290
