2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
3317の回答 すべて表示
Horizontal black flickering lines after screen replacement?
After cracking my screen, i decided to replace it. All seemed to go well but when I assumed I had finished and tested the screen there were flicking black lines all over the screen.
I have checked the connections several times now
and I have tried a hard reset to no avail.
Phone is functioning fine for calls, camera, charging, everything just the screen is flickering constantly and it is extremely annoying.
I've tried to upload a picture, hopefully you can make out the lines.
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
当社のショップを閲覧する
9回答
選択されたソリューション
most likely a defective part. i would return and get another part.
この回答は役に立ちましたか?
スコア 2
コメント:
I'm having the same problem and I haven't had to take my phone for any repairs I was watching a music video one day and then my phone just stopped and got all static like how you just showed i don't know what's wrong with that eaither it's never done this before
による
コメントを追加
最も参考になった回答
I had the same problem with horizontal lines. I tried unplugging and plunging the cables many times and it did not work. I tried cleaning them and it did not work. Finally I realized that when I change the position of the screen at a certain angle it stops. After an hour of trying to figure it out, I realized that there is a chip like component in the new screen where all three cables are connected to the screen. (See the image) When you bend the cables and try to place the screen in the right position to complete the installation, that chip like component touches the screen itself and it makes flickering. I just places some paper behind that component so that it does not touch the back of the screen. No more flickering. At the end of the day, it was mainly because of the new screen's cable connections. If you can not find the right spot and fix it, return the item and get a new one.
この回答は役に立ちましたか?
スコア 6
コメント:
This fixed my screen. Thank you very much.
による
can i ask specifically how ?because this is like my problem when i tilt the screen the lines goes away please help
による
omg thank you!!!!!!!!!!!!!!!!!
による
コメントを追加
Yea can make the lines out..
You could try and clean the lcd contact on the screen and on the logic board board but failing that it's possible you have gotten a faulty screen.
If you don't mind me asking were if u purchase it?
この回答は役に立ちましたか?
スコア 3
コメント:
Hi, Thanks for the reply.
Yea, ill give it a try. Is there any thing in particular I should clean the contacts with?
I bought the screen from ebay, and attached a separate home button and camera because it worked out cheaper. Both add ons work fine just the screen.
This is the link
http://www.ebay.co.uk/itm/Replacement-Fr...
による
コメントを追加
This could be a bad part, or it's also possible that you bend the cable too sharply.
この回答は役に立ちましたか?
スコア 2
コメントを追加
I tend to stay away from ebay its hit and miss.
The screen you purchased probably is just a low quality copy
I would return and get a refund if you can.
この回答は役に立ちましたか?
スコア 1
コメント:
I agree, I didn't mention earlier but the build quality is very poor as well. After fitting the screen the first time and seeing it wasn't working, I obviously had to pry it back up from the phone with a small suction cup (provided) and the glass began to peel away from the digitiser slightly on one side.
So, I've opened up a case for a refund on ebay.
Could you recommend any where for purchase with reasonable pricing?
による
try mobiledefenders.com they ship fast and have done good business with me.
による
コメントを追加
I have the same problem and have noticed when I connect the screen lcd cable by itself I don't get the lines... but once i connect the touch sensor cable and the camera I have a the lines... is it a short?
この回答は役に立ちましたか?
スコア 1
コメントを追加
I have the same issue, I've tried connecting and reconnecting the display many many times to no avail, I was assured this was a good part and I have not bent the cable too much (I was very careful) ... any suggestions are welcome, thank you!
この回答は役に立ちましたか?
スコア 0
コメント:
Update: I have had to assume the screen as defective. I managed to get the lines to disappear in exchange for very very low brightness and some ghosting on the corners. I have now been refunded by the seller and will be looking at other alternatives.
による
コメントを追加
I had this problem too
Contacted the seller and returned it for a replacement
I noticed if I tilted the screen from side to side, the lines would disappear, but reappear when put straight
Seller was direct and offered a replacement, but I think I buggered my board trying to troubleshoot the problem and my home button doesn't work now
Ugh!!!!
この回答は役に立ちましたか?
スコア 0
コメント:
I have the same problem, and when I touch the top left of my screen it goes dark, and when I turn my phone on lines come on and won't let me be able to touch my screen without making my screen go dark in order to work.. any help ?
による
コメントを追加
Yes only solution to change the display .
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brian さん、ありがとうございました!
統計データを表示:
過去 24時間: 6
過去 7 日: 52
過去 30 日: 233
今までの合計 58,164
