Where is this battery card located in the laptop?
Where is this card actually located in the laptop - not covered by any guides.
Thank you.
この質問は役に立ちましたか?
Thank you.
この質問は役に立ちましたか?
In either the older Onyx or newer DVI models the PRAM battery is located under the optical drive.
Here's the DVI IFIXIT guide PowerBook G4 Titanium DVI PRAM Battery Replacement.
Here's the Onyx IFIXIT guide to remove the DVD drive PowerBook G4 Titanium Onyx DVD Drive Replacement. You can see the PRAM board here:
It's the same board and the battery is soldered onto it so you do need replace the board unless you can get the battery with tails. Here's the IFIXIT part: G4 Titanium Onyx or DVI PRAM Battery
ガイド
難易度:
中レベル
ガイド
難易度:
中レベル
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 70
