メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
3282の回答 すべてを表示
phone wont turn on
My iphone went flat as I was talking on the phone I quickly put it on charger then once it turned on it was just a black screen and started vibrating continuously for quite a few hours I took it off charger left it vibrate hoping it would die once it goes flat again it did stop the vibrating but now a few weeks later I put it on charge and there is not even any light or anything what should I do help please?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
Did you try holding down the on/off and the home buttons at the same time for 30 sec?
による
コメントを追加
Android 修理キット
A new screen or battery is one kit away.
ショップを見る
Android 修理キット
ショップを見る
3回答
最も参考になった回答
Try what that eman05 wrote If that does not work there could be a need for strengthening the contacts screen or the screen is burnt out and require replacement.
この回答は役に立ちましたか?
スコア 1
コメント:
i've tried holding the home, on/off buttons together for 30-60 secs that hasn't worked at all?? how would I go about strengthening the contacts screen?
による
コメントを追加
I would remove the battery take the two screws out from the bottom and slide the rear cover up now undo the screw in the battery and gently lift the battery connector up til it pops out now press power to drain any power that was in it for 3 seconds. Then reconnect battery and try to power up..
この回答は役に立ちましたか?
スコア 1
コメント:
Thanks I Shall Try That :)
による
Think he means buy strenthing the contacts is just make sure you have them snapped in place proporly
による
Thanks I'll check it out also :)
による
Let us know how you get on you
による
I've Just received my battery today and replaced it but nothing has happened not even any light coming on or anything... Any Other Advice???
による
コメントを追加
My phone turned black wheni was talking to someone and my lock button is broke. So i tried pressing the home button and it doesnt do anything. But when i put it into the charger it dings but doesnt turn on. Siri starts talking as well. It is really weird but idk what to do.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shenika さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 166
