Windows 8.1 drivers for Asus Laptop R505CB?
Hi all,
I have installed windows 8.1 in Asus R505CB but in Asus suport webside, they do not have all the drivers needed.....does anyone know how or where could i get them?
thanks
You can use driver program such as DriveTheLife to install all drivers for your Asus Windows 8.1 computer. It is very easy!
このアンサーは役に立ちましたか?
If you can find Drivers for Windows 7, you can try to use them, in most cases they work fine.
Please check, what architecture you are using and download the correct drivers (64bit or 32bit).
このアンサーは役に立ちましたか?
If you can' t get compatible driver from Asus official support. You can try to use this way: install Asus drivers for Windows.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 304
1件のコメント
Which drivers are not installed?
ZFix さんによる
