How do I remove the Logic Board from the base?
I need to replace the lower base, but can't seem to locate all the screws that attach the logic board to the base? Any ideas?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Make sure that all removable parts of the logic board such as RAM and the airport card are removed. Then, take out all the screws that you see on the logic board.
このアンサーは役に立ちましたか?
Hi. Thanks. There were a couple of screws I couldn't locate. There was a plastic screw which I hadn't identified and also some smaller Torx ones near the power socket. All sorted now.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 202
