メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
締切られた回答
Drop my iPhone in water
I dropped my iPhone 5 in the toilet I opened it up took it apart and placed it in a bag of rice for 24 hours used a replace battery but all it does is turn on and stay at the apple logo is my phone dead or is there still hope ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
adeaga1239, rice is a good desiccant but it does not fix your phone, nor will it prevent corrosion. As with any phone, I strongly recommend that you clean it. Disassemble it by using these guides. Clean it properly using this guide. It was written for a 3G but all the points still apply to your phone as well. Once it is properly cleaned '''replace the battery" reassemble and re-evaluate. With a new battery and properly cleaned, you will have a good starting point should any further trouble shooting be necessary. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hay adeaga1239,
try to see if there is any corosion on the board and if so i suggest you take a anti static brush or used tooth brush...(-: and remove with caution.
hope you success,
Oria
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
since the emi shields are soldered onto the iphone 5 logic board, you really can't get at most of the board or even see it.
disassemble the phone and drop that board in some isopropyl alcohol 90%+ skip the useless rice and let it air dry.
reassemble with your new battery and post results.
remember to try a hard reset if your phone is hanging on the apple logo (power button plus home button 10 seconds together)
jessa
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 209
