Error 4005 Wont boot up but shows up in Itunes (DFU)
My Wife's iPhone 4 up and quit a few weeks ago. No signs of life on the charger or in iTunes. The dock connector was pretty corroded so I replaced that and the battery with no results. If I put it in DFU mode , it will show up in iTunes but gives me an error 4005 when trying to restore. I metered the charging fuses on the logic board and they seem OK. I'm guessing that would leave the charging IC ? Or am I looking at something else on the Logic Board as the cause?
Brian, are you using (or have you used) iCloud backup on this phone?
oldturkey03 さんによる
Yes it was running iOS 7 with iCloud activated.
Brian さんによる
If it is not a hardware error, you can try this method.
The Easiest Way to Fix iPhone Error Code 4005
SarahPalin さんによる
