iPhone 5 won't boot after disassembly, is my iPhone a paperweight now?
So here's the pre-story: my mom's iPhone 5 has been having problems with the sleep/power button. It wouldn't work at all. So, figuring there might be dirt, etc. causing the problem, I pulled it apart following a guide.
I cleaned everything out, made sure I was being very careful, using all the proper tools (utilizing my brand new iFixit Pro Tech Toolkit), etc. I got everything back together, then powered the iPhone on.
The good news: the power button worked!
The (very) bad news: about 5 seconds into the boot process (showing the Apple logo), the screen dims and some text appears, as if it were booting in verbose mode. Here's the text:
[NAND] _FindFlashMediaAndKeepout:601 physical nand block offset 1
[NAND] start:356 this 0xa3148400 PROVIDER=0xa16f5e80 flashMedia=0xa16f5e80
[NAND] WMR_Start:149 Apple PPN NAND Driver, Read/Write
[NAND] WMR_Start:174 FIL_Init [OK]
[NAND] WMR_Open:371 VFL_Open [OK]
[NAND] s_cxt_boot:88 sftl: error, unclean shutdown; adopted 697 spans
[NAND] WMR_Open:420 FTL_Open [OK]
[NAND] _publishServices:642 FTL capabilities: 0x0000001
[NAND] _ppnvflGetStruct:3469 Checking borrowed blocks - count: 23 max_count: 23
[NAND] _fetchBorrowedList:881 number of borrowed blocks 16
Please help! I really hope this is fixable. From my (minimally educated) look at what I wrote above, it seems like the problem is either the unclean shutdown or physical memory. *panicking* Thank you in advance for your help!!!
6 件のコメント
Update: found Tyler Farrar's fix over here, pulled off the front facing camera connector, now she boots like a charm. I'm going to dig around some more and get back to everyone.
Christian さんによる
Alright, got everything fixed, for the most part! Thank you everyone for the help! :)
Christian さんによる
So how did you end up fixing it?
Laurens さんによる
Laurens, he's telling us that it was a flex problem as predicted (read my answer below). Start by isolating which flex is causing the problem by taking them all off except power and adding back one by one.
jessabethany さんによる
The best way to repair your troubles is opening over your iPhone,and remove your battery connection for few seconds wait a little bit and reconnect your battery and your screen afterwards and Voila!! you should be all set...Any questions my name is Barri.
Txomin Arambarri さんによる
1以上のコメントを表示
