LCD working but no backlight.
I have a black 2008 macbook with a screen that displays images but without a backlight. The LCD will flash white when it is first turn on and then turn black. Using a flashlight, I can see the login screen on the LCD.
If I set the backlight to 0 and then to the lowest setting, the backlight will flash on and then turn back off. Sometimes, if I'm lucky I can raise the brightness to 4 before the backlight turns back off.
So far, I have:
- Replaced the inverter, no change
- Used compressed air to clean the inverter connections, no change
- Reseated the LCD connections, no change
- Reseated the connectors from the inverter to logic board, no change
この質問は役に立ちましたか?
4 件のコメント
One more thing - when the brightness is at its lowest setting, the backlight flickers before shutting off.
Jack Byrnes さんによる
Jack Byrnes, what are the last three digits of your computers serial number? this will help us to identify your computer properly.
oldturkey03 さんによる
The last 3 digits are: 0P2. Its a 2008 black macbook with a 2.4ghz penryn
Jack Byrnes さんによる
2.4 GHz Core 2 Duo (T8300)
Intro Date: February 26, 2008 Disc Date: October 14, 2008
Order No: MB404LL/A Model No: A1181 (EMC 2242)
Subfamily: Early 2008 Model ID: MacBook4,1
Std RAM: 2 GB Std VRAM: 144 MB
Std Storage: 250 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
oldturkey03 さんによる
