Why can't I remove the ram?
I'm trying to remove the ram based on ifixit instructions but it won't come out. What am I doing wrong?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Of course your remembered step 2. The connector can still be a very tight fit. Use the spudger to chimney or lever one side back then the the other by pressing/pulling on the edges (notches) until the connector releases the chip.
If you have a third hand to pull on the middle of the chip you'd be better off.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 82
