メインコンテンツにスキップ
Fix Your Stuff
Right to Repair
Parts & Tools
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
262の回答 すべてを表示
Power supply compatibility (iFixit store)
I have a 17" intel iMac which has a pretty strange problem. Sometimes it works fine but it often doesnt want to start AT ALL (no light,....) This model has no led inside to diagnose the problem.
As it sometimes accepts to start up, i think that the motherboard is ok, and the power supply guilty. So, I would like to replace this part myself. My only question is the following :
Will a power supply owned @ iFixit work on a european (french) iMac ?
I mean, you americans use 110V/60Hz powerage and we use a 220/50Hz one. I wouldnt like to turn my iMac into a barbecue.
Thanks to everyone !
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
Vincent Monteil, it is my understanding that the PSU is rated for 110V-240V 50/60HZ so it should work for the European market as well. Best bet of course is to get confirmation from the vendor. If you want to purchase it from ifixit I suggest to contact them directly on here. Hope this helps, good luck.
この回答は役に立ちましたか?
スコア 1
コメント:
That is a nicer answer ! Thanks !
さんによる
コメントを追加
Be aware that this is the volunteer DIY help forum - we are not iFixit employees. To contact iFixit directly use the link at the bottom of the page.
If this answer is acceptable please remember to return and mark it.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Vincent Monteil さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 101
