メインコンテンツにスキップ
Blue screen with MacBook Pro A1150
I have a MacBook Pro A1150 2.0Ghz.I am frustrated with the blue screen problem.This MacBook can be started,but after bang, apple logo, it stays in the blue screen mode.The service center told me to exchange a logic board. Is there a way to repair it rather than changing a new logic board at $600?
Thank you for your help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
2 件のコメント
This post does not belong in meta, it belongs in iFixit Answers, meta is for discussion about the Answers forum itself. Post there and you'll get help.
さんによる
If you put this as a note to the original topic and flag the topic, an admin can move it, I think. (I've already flagged it)
さんによる
コメントを追加
2件の回答
ベストアンサー
Try starting up from your system installation disk by inserting it and holding down the "C" key. On the second screen the pull down menu will appear. Go to Utilities - Disk Utility and repair your hard drive if you can. If it does boot, then the logic board is OK and you need to look at repairing the system, re-installing the system or if the hard drive is not seen then replacing the hard drive.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
good answer +
さんによる
コメントを追加
It's stuck in blue screen because it's dying loading GPU driver. You have an X1600, they are all dead by now. They are far beyond their life expectancy. :) These were terrible chipsets when they were new even the ones intended for desktops - the ones for laptops are just frightening. Particularly ones with poor cooling design.
Usually the repair is replacing the dead GPU with a new one. None of that reflow/reball BS you read about online, the problem is not in the balls, it is in the GPU! With A1226/A1260, you can replace the G84-603-A2 and have a reasonable fighting chance it will work. With A1150, A1151, A1211, A1212, A1229, it is X1600. X1600 it is just dead and you will NEVER find a new GPU. Just reballed, remarked junk from Chinese sellers who claim it is new, when it is not.
If you do manage to find the one last X1600 remaining in the world that is new and try to solder it on - the Samsung VRAM on the board will die while replacing the GPU.
So for X1600 based anything, the only logical answer is to toss it in the bin. :(
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Huifeng Gu さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,789
