Screen is very dark
Upon start, screen stays very dark. I can barely see the login screen, and can't read any icons. Tried using the bright key, tried replacing inverter and cable. No improvement. Any advice?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sounds like a failed inverter to me. Please give us the last three figures of your serial number (found in the battery compartment).
このアンサーは役に立ちましたか?
The CFL's are likely going. Try lowering the brightness to the lowest setting then hit it once going up did it brighten up for a sec, or did it do nothing? If nothing happened the CFL's are gone in the LCD panel.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 107
