Will a iPhone 5 home button fit a iPhone 5c?
Says it all in the title.
Apple iPhone 5cは2013年9月10日に発表されました。このデバイスの修理は前モデルと類似しており、スクリュードライバーとこじ開けツールが必要です。GSM か CDMA、8, 16, 32 GB 、色は白、ピンク、黄色、ブルー、グリーンがあります。
The home button itself and its gasket is the same size between the 5 and 5c as far as I can tell, as I have both in front of me now and just swapped them no problem.
There is one minor difference in the black button as the button on the 5 has a black ring surrounding the metal dot on the back and the 5c has a white ring, which makes the square on the front of the button to appear whiter than on the 5, which appears dark.
The flex cables with the button attached are definitely different though.
コメント:
The flex cables seem to be different in shape, but not in utility. The connectors are in the same place, aren't they? I might try installing it and seeing...
Talon さんによる
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 6,381
